Jul 25, 2004 #1 Y yoe Member Joined Jun 21, 2004 Messages 41 Location Sheffield Car W210 2000 anybody knows what this part is?.. need help please
Jul 25, 2004 #2 R Robbo Active Member Joined May 4, 2003 Messages 850 Location Berkshire Car C320 (W203) & A170 (W169) Isnt that the purge valve? Very common problem for it to be clicking. I believe you can get a new one with damped mountings to reduce the noise.
Jul 25, 2004 #3 OP OP Y yoe Member Joined Jun 21, 2004 Messages 41 Location Sheffield Car W210 2000 i haven't got a clue about this purge valve.. very annoying sound. it this mean that i have to get a new part?.. Last edited: Jul 30, 2004
Jul 26, 2004 #4 guydewdney MB Enthusiast Joined Feb 14, 2004 Messages 2,911 Location Porlock, Zomerzet Car 906 Sprinter 313cdi regeneration valve? 70 us dollars (50 quid?) - it allows fuel vapour to be re-used. normal for it to click, epc rants on about chassis numbers and changes etc etc can you pull a part number off it? prob 000 470 xx xx? Guy
Jul 30, 2004 #5 OP OP Y yoe Member Joined Jun 21, 2004 Messages 41 Location Sheffield Car W210 2000 yah the part number is correct. how do you know whether this part is working or not?.. Last edited: Jul 30, 2004
Jul 30, 2004 #6 OP OP Y yoe Member Joined Jun 21, 2004 Messages 41 Location Sheffield Car W210 2000 yah the part number is correct. ho do you knows whether this part is working or not.?.. i little working about the clicking sound.. thank's
Jul 30, 2004 #8 OP OP Y yoe Member Joined Jun 21, 2004 Messages 41 Location Sheffield Car W210 2000 how to clean it?..
Jul 31, 2004 #9 guydewdney MB Enthusiast Joined Feb 14, 2004 Messages 2,911 Location Porlock, Zomerzet Car 906 Sprinter 313cdi PULL IT OUT. STUFF 12 VOLTS ON THE CONNECTOR turn off caps lock it should now be 'open' and you should be able to blow through it. its just a simple valve as far as i can see...
