E270 cdi Oil change frequency?
Every now & then I see good brand oil discounted and stock up. Last year I bought Castrol Edge ridiculously cheap in The Range.
Tesco often have deals.
Multi buy good quality filters on eBay.
With an extractor it’s a ten minute job including a cup of tea!
Oil is oil as long as it meets spec , I never bought branded or MB oil , always run on cheap one , No issues at all even on high milers
I agree with 'any oil that meets the spec', but I would elaborate.
I am sure that there are differences between oil products, and that some are better than others. Oil companies independently invest large sums of money in R&D, and it's likely to yield different results for different manufacturers.
There are two points to note, however.
The first is that it can be nigh-on impossible for consumers to know which product is actually better. We go by brand reputation, and opinions of 'oil experts', but ultimately the only way to find out is by running a controlled tests on a number of identical engines using different oils then take them apart and check the engines for wear. And, the results will likely be different for various driving scenarios, e.g. motorway miles vs city driving or cold starts, etc, so will also depend on how the car will be used. These experiments have been done, but in very small numbers and the little information that currently exists in the public domain won't help you choose when standing in front of a shelf stocked with various oil brands.
The second is that even so, whatever differences that may be found between oils that meet the MB spec, will mostly be irrelevant. Does it really matter if the engine will be good for 200,000 miles or 220,000 miles? In the majority of cases the answer will be No. Whatever differences there are in protection against wear, they will (again, in the majority of cases) not be noticeable under your ownership. How many cars these days outlive their engines? Very few. Cars get scrapped well before the engine reached the end of its service life (as result of normal gradual wear).
As long as the oil meets the spec (and bought from a reputable source, so it's not fake) it will do the job.
Nothing wrong with MB-branded oil, or Triple QX, or any other oil that meets the MB Spec Sheet.
BTW, the MB-branded oil is rumoured to be made by Petronas, ECP's Triple QX by Shell, but either way it doesn't really matter.
Triple QX is Tetrosyl , as is the supermarkets own , G Force , Carlube Triple R , and possibly Halfords own .
So where do Tetrosyl get the oil from? Not that it matters much.... just out of curiosity. Their website says that they are the 'UK's biggest independent oil blender', so they obviously don't produce the oil themselves.
Basestocks from one of the major suppliers , it's not important as group 3 is group 3 , 4 and 5 , industry standards .
No different to the Mercedes 'own' brand .
As you've correctly said , one of the secrets of the oil industry is that these mostly cheaper and supermarket brands are actually the same quality oils that are produced by the major oil companies .
The only difference between these products and the major company brands is the name on the container and the price .
Likely I've missed something, could this be an ABS sensor?
I got live data from all ABS sensors but as I had a new one fitted that but still the same so its the reluctor ring, the only reason its not been done is I needed and 18 and 16mm spanners to do it so ordered some off Ebay and they seem to have been lost in the post so trying to get the seller to sort it is causing more hassle thn doing the job!
I see what some are saying on none branded versus branded but for my piece of mind I like a branded oil, so will go with the MB oil just so I can sleep at night :D . I never thought my post would generate so much healthy debate so thanks all for your input.
...As you've correctly said , one of the secrets of the oil industry is that these mostly cheaper and supermarket brands are actually the same quality oils that are produced by the major oil companies .
That, and the fact that you are buying a pig in the poke. Without the manufacturer's reputation behind the product, you might be buying something that is the same, better, or worse than the manufacturer's own-brand products. There's just no way to know
My point wasn't that all oil products on the market are the same - I am sure they're not. My point was that whatever differences in quality that may exist between various oils that meet the same MB Spec Sheet, it will be irrelevant for the majority of car owners.
