E320 203 body error code
Bobby Singh
Hi does anyone know what error code "115 - Electric intake vent, engine,A/C signal improper" means??
By the way its a E320 203 body.
Cheers
Bobby
Sounds like the dash ventilation vents are out of sync.
That sound like a sporadic fault.
Most of the sporadic faults can be ignored. Whats the problem?
(203 or 210/211?)
Hi DM - how do you know how to re sync these if thats the problem?
The actual problem is air con not working - the system has been re gassed and there are no leaks.
By the way its a 203
Is the compressor running?
If not chec the single signal wire to the compressor and make sure its not broken.
