BIG_G_1979
Any update on root cause of power loss?
I haven't had time to chase it up as very busy with work but as soon as i have it checked will updateAny update on root cause of power loss?
Which hose, where is it located so i can check and either fix or rule it outhave had the same problem for six months because no one could find that.the problem was tiny small hose replaced .
The fuel filter was changed roughly 4k ago but i dont see how that could be as i am only getting like 22-23 mpg around townI have a similar fault with my ML280CDI.
It could be fuel starvation. Have you replaced the fuel filter?
Sent from my SM-G920F using Tapatalk
I did have it tested and it performed beautifullyhave you checked the turbo actuator???
Well well, i have replaced the egr twice now and yet the problem is still there, it has gotten worse really as the car is in limp mode more often than not, when starting from cold its in limp mode, as soon as it reaches the required temperature if i switch it of and on again it starts working but not for long, this car is giving me some serious head scratching of what it could be, never in my life did i have a weirder car
EGR replacements - were they new or used units? If new then assuming genuine MB ones?
If used then they could possibly be faulty / not functioning as intended?
Sent from my GT-I9505 using MBClub UK
