mercanlandy
- Aug 9, 2015
- E320 cdi auto estate elegance
2003 e329 cdi wont start after fuel filter change
I just did basic service on my e320 cdi, changed all filters and oil. it was starting instantly until I changed the fuel filter. Now it will not fire. I have had years of diesel engine servicing under my belt but this is a bit more technical being the cdi and ecu's etc. I also replaced all diesel leak off flexi hoses as one split last week.
I unclipped the center fitting on the top of the filter housing and moved it to one side, I then unscrewed the large round top off the filter housing, I replaced the fuel filter, refitted the top of the filter by screwing it back on nice and tight, I reattached the center pipe and clip in place then tried to start it but it is not even coughing now. What is the method to manually bleed the injectors on a cdi if it will not self bleed. On the older simple diesels I would crack open the injector pipes and wait for fuel to squirt out then nip them back up. Can this be done on a CDI fuel system.
Or is it just keep crancking till it decides to fire up again.
I have gear selector in "P" so it should know it is ok to start up, I have filled up fuel filter housing as much as I could till it was up to top of housing, but still not starting.
Getting desperate now
SC
SC
