Panicked a bit when you mentioned 28mpg, but I'm sure I can get that into the 40's. My husband took it for a test drive. He's an Audi driver and after driving it I think he is converted.You don't buy a V6 for economy.![]()
Thanks, sounds like I'm going to enjoy driving it. It will certainly be a different experience to my C220Don't worry, ignore the 28mpg claim. My 2011 265bhp E350CDI with 7g+ 'box averaged 38mpg over the 35,000 miles I drove in it. I'm sure you'll achieve similar (or better) with the use pattern you mentioned earlier in the thread.
Enjoy your new purchase - they're a near perfect mix of refinement and performance that doesn't break the bank by guzzling diesel.
I drove an E250 before I bought my 2010 231 horse E350....I found it pretty harsh and noisy (TAXI!) To be honest... the V6 was a much nicer feel. You guys have must lead feet! ...28mpg!..... I've not done a tank top to tank top measure yet.....but assuming the dash reading not miles away I'm getting rather more than that. Mixed driving gets me 33 or 34.... on the motorway its 40 ish.....but probably would be better if I drove like a normal human being...I like using the paddles and making that V6 sing! Gotta say that for a derv it sounds great....if anything it could be a bit louder....very un diesel like.![]()
Just 540 nm (398 ft lb)with mine....
When you mention earlier models what year are you referring to?I have the E250 and it’s a great balance of performance and economy, one thing that put me off with the early 350 is if the oil cooler seals go, it’s a big job to change and a known fault on early models. The 250 is very reliable motor , only fault I have heard is the cam chain tensioner can get sloppy, I do frequent oil changes and turn off stop/start to help with this.
Great, thanksDon't worry about earlier models is my personal view. I think oil cooler seals will need changing circa every 100k miles regardless of the later car 'upgraded' seal.
I am happy to be proved wrong on this, but I would err on the conservative side and assume that if the car you are buying doesn't have a receipt for oil cooler seal replacement, it will be needed, so budget £1k.
Great, thanksThe car has a full MB Service history. I could check with them if it has been done.
Great, thanksThe car has a full MB Service history. I could check with them if it has been done?
Yes, no airbag recalls on the car, all goodDid you check to the airbag recall on your car ?
I will maybe contact them and ask if it was done at any stageOnly if you ask the dealership that serviced it, and only if it was done at a dealer......
120K miles on this one too, so will have it checked when I take it to my mechanicIt's not a serviceable item unfortunately. You can ask but I doubt anyone would pay mb prices on that job.
My father's ,2007 e320 same engine, was on 127k with no oil leaks from the cooler
Hopefully it’s been done then, save you £1000, the new seals were purple.120K miles on this one too, so will have it checked when I take it to my mechanic![]()
The new seals were used from around 2010 .Hopefully it’s been done then, save you £1000, the new seals were purple.
E350 Cdi OPM642 NS Lower Engine Leak
Hi Guys, Just noticed this and wonder if anyone know where this might be likely leaking from? Are those 2 pipes the diesel lines?forums.mercedesclub.org.uk
....The car has a full MB Service history....
The new seals were used from around 2010 .![]()
