- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
Changing the viscous coupling on the E430 looked a pretty-simple job.
(Bad mistake #1)
I guess the photos speak for themselves.
Someone has been there before me and has butchered the 36mm hex nut that secures the coupling to the water pump pulley.
I have given it everything I've got with the correct spanner and the correct tool for locking the water pump pulley.
Can't shift it
First question ... If I remove the four hex bolts that secure the pulley to the water pump flange, can I then lift out the pulley with the VC attached.
If so, I can then get it in the vice and remove it with some brute force and ignorance.
Second question ... It's far from obvious how the poly-V-belt is tensioned.
The owners' hand book is no help at all.
The Russian site shows a fitting diagram with 8 pulleys ... One of which is called a tightener pulley / sheave pulley.
Unfortunately, this car only has 7 pulleys and the tightener pulley is not there.
Any guidance would be warmly-appreciated.
Thanks in advance.
(Bad mistake #1)
Can't shift it
Thanks in advance.
