Just been informed that my front boots are down to the string on the inside corner yet the rest of the tyre is 5mm of tread all the way across.
Does lowering the car effect camber on an e55? I have a Renntech ELM which I have adjusted, it was installed by previous owner and for a while I've been meaning to read up on it and adjust as the front was on the floor with the back sat up i little IMO, the settings on the front were extreme, 45mm lowered when Renntech suggest no lower than 25mm, so the car now looks more level and sits better, I'm hoping that this will help sort my tyre ware issue.
Is the front camber adjustable on an AMG e55?
