G7Wagen
Link to the C43 Engine failure posts.. C43 engine failure | AMG Lounge
Agreed how can it possibly cost 9k to see what went wrong???It is ridiculous to have to spend 9k on a bet to see if they will cover it or not. I do not know how that works.
It can't, but I presume, they are hoping he'll quietly go away, throwing stupid figures at him. Hope he gets a good outcome.Agreed how can it possibly cost 9k to see what went wrong???
It's a good strategy for the dealer because it becomes very difficult for you to do anything with the car once they have started to strip it down; it makes your bargaining position weaker. This ought to be as easy as it gets; prestige top of the range expensive car, one owner bought new so no doubts about the history, only 3.5 years old, serviced by the main dealer, only 6 months out of manufacturer warranty...........It is ridiculous to have to spend 9k on a bet to see if they will cover it or not. I do not know how that works.
Amounts to about 50 hours work at an MB dealer. I find it hard to believe that it takes in effect over 6 working 8 hour days to strip a motor but I've never done an MB one.It is ridiculous to have to spend 9k on a bet to see if they will cover it or not. I do not know how that works.
And you wouldn't need to strip the motor in one go. Drain oil and check for swarf and chunks. Drop sump and inspect lower engine. Inspect top end with camera thru spark plugs holes. Then decide next steps.Amounts to about 50 hours work at an MB dealer. I find it hard to believe that it takes in effect over 6 working 8 hour days to strip a motor but I've never done an MB one.
I must have miss that video, it's a good'en. I bet AMG know about this and the effected engine numbers too^ This is what I’m talking about
I guess there will be an occasional bad batch of engine out there. Or an engine builder who was drunk during assembly but these early / low mileage failures are worrying, especially as the engine is stock and dealer maintained.It’s not remotely common, but not entirely unheard of for M177 to have issues with over-tight main bearing clearances from the factory. It leads to crankshaft seizure, usually propagating from a main bearing initially, but overheat quickly spreading to big end bearing journal and then ultimately seizure. I have an old school attitude and I won’t repair an engine after a failure of this magnitude. I believe Tasos did repair one, but it wasn’t a total success iirc
So much complication in modern engines. Oil on demand, for example. Far too many potential failure points.
What I meant was, in law, your contract is with the dealer, the dealer's contract is with MB and MB's contract is with whoever supplied the faulty component that caused your car to go bang, and so on... hence you chasing MB is a good idea but it is not one that stands legally. Legally the dealer has to honour their contract, and if in doing so they are out of pocket then they should seek recompense from MB.Some suggestions to consider: Try a forensic engineering company for a quote for the engine investigation. Tell the dealer the car was not of sufficient quality to be saleable (no reasonable person expects a car engine to fail at 35k). If they will not investigate for a reasonable amount then you will engage a forensic investigation and charge the dealer for the bill. Remember, your 'contract' is with the company you bought the car from, not MB. You need to force the dealer to chase MB and the only way to do that is to let them no you are taking no prisoners. You might have legal cover on your car or house insurance that will entitle you to speak to a solicitor for advice: a letter from them or you quoting relevant law will be extremely useful. Good luck
