Early Audio 30 with phone wiring diagram needed
PeterE320Cdi
Devon
C219 CLS 320 CDi, R170 SLK 230K, XC60 Past Cars: S210 E320 CDi rusty, CLK 240, S210 E300 DT
I have a year 2000 W210 E Class with Audio 30 and the original phone installed. The Nokia 3110 like this.
http://discussions.nokia.com/discussions/attachments/discussions/accessories/16703/1/P1080263.jpg
The radio broke so I decided to replace with a new radio which has bluetooth built in.
Only problem is that I can not find the live ignition wire. All the wiring diagrams I can find online are for the later models which have 5 wires in the A block pins 4, 5, 6, 7, 8. Mine has only 4 wires in Block A in pins 2, 4, 5 & 8
http://t0.gstatic.com/images?q=tbn:ANd9GcRW1FFY026EH-CaVjSwOhqkfOEhTNuMgBWzQ4wZ9kzNpG4gGi7a
I have found the permanent live feed and the earth but the other 2 wires show no voltage with the ignition on. To get the radio working I have had to wire the ignition wire into the permanent live feed which means I have to manually switch off the radio.
So does anyone have a wiring diagram for this early version of Audio 30?
Thanks, Peter
You will be missing a switched live an aftermarket radio will require. You will need to wire this in. Most people take it from the back of the cigarette lighter.
