Dedge86
I'm in need of help
I have a v230 and the crank sensor needs replacing.
The issue is mine has integrated wire and oval 8 pin connector but the only 2 i can find anywhere are sensor with plug and no wire (common) or integrated wire but with round connector and single plastic type pin and obviously neither of them fit.
Has anyone ran into and overcome this issue or know the part that I'm looking for?
Part number on sensor 002153928 and integrated wire 8 pin connector has 140 540 33 81
Also as a side note where does the other end of the crank sensor wire go to?
Cheers
Cheers
