Oh dear.- no it is petrol, of course but it still has same MAF
I have the same symptoms - 98 SLK - this failed overtaking a lorry on a hot day. - no intermittent failure. Since then it revs to 4500rpm in 1st, then to about 3800-400 in 2/3/4th. you need to come of the gas to get it to change up.
Lovely and smooth up to that point, stable idle.
Mercedes Coventry put it on Star and said it was the brake switch.
Then they took it out and though it was cured to start with, it then broke again and went back to exhibiting the same fault. - Yeah, right!
I did not pay them to fit this switch.
They put it back on star and now say it is the recirculating air valve (£483 fitted). But if I take off the tube from this and rev the engine the flap appears to be working fine. I said I thought it was the MAF and they say they checked this and it was OK (8-13 sthg/hr and mine was 12 - but surely it needs to vary with load/revs according to the very good graphs presented earlier).
The only thing they will do next is change the air valve.
Can anyone suggest anything more sensible/cheaper than this?
