electric aerial
Whats the noise like? My current arial is noisy as buggery and I think will end up dying on me soon
its really smooth,and looks fantasic in the black finish,they also do the chrome as well,
really quiet,have to look around just to see if its up:bannana:
I would like to fit one of these, only problem is mine has non - electric aftermarket fitted on wrongside of car at rear, (see car pics) what would I need to do to fit one..
ie.. would it fit in same place or would i need to get hole filled and respaired and fit on other wing??? re-wiring is not an issue.
i dont no for sure:confused: ,but if you have enough room in the boot,ie where your one is at the mo,i cant see why not,all i done was peel back the boot carpet,and there is enough room ,but you might have to make up a fixing bracket,i did not use the ones supplied as original one fitted,i will try to get a pic
just thought you would like to no,i had to replace my original aerial and found these on ebay
cant recomend enough and for £38.95 for a all black one ,i fitted in 20 mins:rock: :rock:
http://stores.ebay.co.uk/car-masts-uk-shop
this was the one i had
http://cgi.ebay.co.uk/Hirschmann-El...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
and delivered the next day:bannana: :bannana:
i have to agree, i used this one before to buy a new circuit board for the aerial as the original packed up, it was only £12 delivered, i thought that was a bargain.:D
