c240Cclass
- Dec 2, 2007
Three problems fellas, would appreciate your advice!
1. This car has been in the family 8 years but the sunroof no longer works.
If you tilt the switch to tilt the sunroof, it SLIDES back, but then it will stop 4 times on the way to fully open.
Again to close it, you must use the 'tilt' part of the switch and again it takes 4 seperate on/off's to get it shut.
Does it need a new motor or switch?
2. Also the dash board lights behind the fan control & swich directly above it do not work - is there an easy fix?
3. Anywhere specifically you guys would reccomend for good quality aftermarket replacment mats?
Thanks alot, I would really appreciate any help.
Robin
Robin
