R129-300-24
I have a 1991 SL 300-24 R129-61 with an electrical problem.
The symptom is that, intermittently, (80% of the time), when the indicators are used (left or right), oil warning light flickers on, the fuel gauge drops back to zero and back up to its original position AND the cruise control has an instantaneous surge which borders on "interesting!". When stationary, with ignition on but engine off, the symptom is the same (expect the cruise surge, of course!). An independent auto electricion pulled out the intrument pod looking for a dry joint but found no faults and no fix. I've now been advised it could be the relay, part no 129 820 10 26, but I'm wary of spending loads of dosh to find it's not the problem. Has anyone across this sort of problem before or any idea of cause?
