CharlesJones
- Aug 10, 2007
- 1982 Mercedes W123 230E Saloon, and a 1984 Porsche 911 Coupe.
Hi everyone,
I am a newbie here, and have owned a w123 230E for about 6 months. The car is an absolute joy to own, but has recently developed a very odd problem where the engine refuses to shutdown even after I remove the key from the ignition.
I have done search for this and found lost of threads concerning similar problems, but its almost always with diesels and usually caused by a vacuum leak. My car is petrol, so I expect the problem is electrical and not vacuum related. Here are the symptons:
Many thanks for your help!
Charles
- When I try to shut down the engine it doesn't shut down, and I can pull the ignition key out and it just keeps running for as long as I care to wait. The only difference is that with the ignition switched off it idles at slightly higher revs - at about 1000 rpm rather than than the usual 750 odd.
- If I then open the drivers door whilst the engine is running on like this (key out of ignition) a couple of the warning lights illuminate on the dash. I think its the battery light, the fuel warning light, and the handbrake light - the ones you usually see illuminated when you first switch on the ignition.
- Now this is the really odd one - when I close the drivers door again the engine stops! This happens every time. I am still using the car at the moment, and when I go to shut down the engine I just remove the key from the ignition, get out of the car (with the engine still running), and when I close the drivers door after exiting the car the engine shuts down!
- Looking in the drivers door jamb I see there are 2 switches which are activated by closing the door. If I manually operate these whilst keeping the door open, I can see that the upper switch turns off the "you left the lights on" warning buzzer and the courtesy light. I don't know what function the lower switch normally performs, but it is this lower switch which causes the engine to shutdown in the case of my electrical fault. With the engine still running, key out of ignition, I can open the door, press in this switch in the door jamb, and the engine shuts straight down.
Charles
