Auto-mobile
My clio 172 that I have turbo charged.
Auto-mobile said:My clio 172 that I have turbo charged.
Koolvin said:my old M116 V8
That is mint .. Do you still own it ?
Koolvin said:Funny you ask that! read this.... http://www.mbclub.co.uk/forums/general-discussion/110195-my-old-mercedes-uganda.html
Is that a ram intake at the back of the engine
Auto-mobile said:There is a gt2860rs at the back on a log manifold.
...Would like to paint the manifold but not sure what to use on it, or should I leave it alone?
What have you done to it altogether and what is the spec of the engine??
Auto-mobile said:Lots.... Basically the engine is a standard clio 172 2.0 16v Full rebuild/hone Custom inlet 630cc injectors Megane 225 plugs H beam rods Forged low comp pistons Log manifold Garrett gt2860rs Forge actuator 2.5" downpipe all the way through exhaust with one silencer Vibratechnic and powerflex engine/gearbox mounts Gen90 aftermarket Ecu Gizzmo Boost controller Forge intercooler 2.5-3" boost pipes Forge coolant hoses Helix paddle clutch Needs running in and mapping still Expect to see up to 350hp and 300+ib/ft torque All work carried out by myself
Wow your more mechanically minded than I am ..are you actually a mechanic ??
Wouldn't mind hearing that engine running bet it sounds mean ..
Mine....
...and another I did earlier...
