Engine Starter Relay?
Jumbojim
West Sussex
CL500
CL500 / 2002
My ignition key will hold over in the starting position, which suggests that authority to start has been given, but 9 times out of 10 the sarter motor does not run, so no start. When the starter does turn the engine starts immediately and runs perfectly. Is there a STARTER RELAY somewhere in the fuse boxes that may need replacing?
You may have a faulty automatic gearbox safety switch which will not permit the starter to operate unless the selector is in the park or neutral position? [ sometimes cycling the selctor lever back and fore a bit can get the switch to work but obviously a temporary fix ] but there are lots of potential places where that initial start signal is not getting through starting at the ignition switch itself. Not familiar with your car's circuitry in detail sorry.
Thanks Grober, I first thought the same, but my INDY's STAR could not prove the fact, and does not the fact that the key holds in the start position suggest that authority to start has been given?
Could it be a failing starter solenoid?
Could be-- I had a similar problem in my old Coupe which a reconn starter from ECP cured- and no problems since.:thumb: There are a lot of complex electronics on these later cars between ignition switch and starter solenoid which why I hesitate to say its that- but if STAR checks out.:dk:
ECP list 2 Lucas reconn starters for your model at £169.20 you pay £241.20 up front and claim back the difference when you return the old one. In my case it was a reconned Valeo- exactly the same as the factory one.
ps those prices are before the forum discount of at least 25%
I'm having similar problems with my car, see 'C63 won't start' nobody at the dealers have suggested a starter relay, maybe different cars different causes.
CL500 / 2002
Hi Jumbojim,
How are you, did you eventually manage to sort out your battery problems? Having only just read this thread, I realise its a few days old now, so have you now resolved this issue? If so, then ignore my post, if not, then I will help you diagnose the problem. Firstly, don’t be confused with some of the acronyms and terminology; I’ll explain what they all are and their functionality later as we go on. I’ll ask you this question first before we go any further, have you by any chance removed or spilt any form of liquid on or near the ESM (electronic shifter module)- gear shift module to you, if so, then you have probably damaged the ESM unit as a result of a short circuit on the PCB. If you haven’t, then that’s fine.
Secondly - The CL’s electrical architecture is an extremely complex networked system and the ETCM, (electronic transmission control module) which is on the CAN C Bus - (also known as chassis CAN) receives all the input (command to start) signals before it initiates the starter lock-out relay to allow for the cranking process. The starter relay on the CL is actually located under the bonnet in the left hand side fusebox, adjacent to the brake servo/master cylinder. When you remove the cover, it’s the second relay down from the top and it should be green in colour. It’s a 5-pin relay and referred to as an SPDT - Single Pole Double Throw with corresponding pin terminal connections - 85, 86, 30, 87 and 87a. I’ll explain what they all are and where they go to later on.
The plus points at the moment are that you have a valid key signature and authorisation to crank the engine, hence, (you being able to turn the key to the crank position) so the EIS (electronic ignition switch)is communicating with the ECM (engine control module) over the CAN network, so that’s one element that we can rule out anyway. Also, you stated that the vehicle “occasionally” starts, so we cannot rule out the communication input link to the ETCM (electronic transmission control module) from the ESM (electronic selector module) which gives an input trigger signal as to its positions regarding “P” and “N” of the shift lever for crank/start safety reasons. What we don’t know at the moment is whether or not the ETCM is actually switching or activating the starter lock-out relay circuit. It’s not that difficult to assess and diagnose, but lets go one step at a time and I’ll take you through the process of how the system actually works and what to check and test.
For now though, here’s a really simple check/test that you can do if you can use a multimeter, remove the relay with the ignition switch in the “off” position and measure the resistance across the relay pin numbers 85 and 86, they should be within the region of between 68 to 72 ohms, (my own CL actually measures 71.4 ohms) if not, then replace the relay as a matter of course. Also, lightly tap the relay several times on some form of solid object and test it again, sometimes the coil windings inside the relay break or the electrical contact surfaces through pins 30 - 87/87a deteriorate and stick together resulting from arcing. It may very well be something really simple such as the relay, but who knows until we investigate. Also try and start the vehicle in the “P” and “N” positions to confirm the ETCM’s acceptance from the ESM - gearshift control module. You haven’t stated anything to the contrary, but can you move the gear selector lever through its full range? Is the solenoid valve actuating/clicking when you press the brake pedal, listen closely to it and let me know if it is?
Please Note - Fuse No. 37 is also responsible for the ETCM and the lock-out relays voltage supply and this is also located to the left of the starter lock-out relay in the o/side engine bay fusebox - (15 amp - blue fuse). Check this fuse for continuity, if it’s blown, then it will be the reason for the communication error between the ESM and the ETCM and the voltage supply to pin number 30 of the lock-out relay, no power - no communication - no crank. The EIS does in fact wake these modules up from sleep mode, and if they are not being powered, then they won’t communicate.
With the greatest respect, and I certainly wouldn’t wish to offend you, but there is no point whatsoever in me going any further with this if you don’t feel confident in working with vehicle electrics/electronics, it does get complicated as we go further on and you can do a considerable amount of damage to the vehicles electrical system and modules if you do make an error, and on a CL they can prove to be extremely expensive errors. Out of interest though, can you actually use a multimeter with any degree of confidence to confirm what I ask you to check/test? Come back to me and let me know what you want to do before I give you any further details, I would sooner you be really honest with me here. In the meantime, check out the above, these are really simple checks/tests and we may not need to go any deeper into this.
Out of curiosity though, what makes you think that the problem is related to the relay or starter solenoid anyway; where did you get this information from, many things can contribute to a none-start? I also noted that you have had the vehicle on a STAR machine with little or no success, with respect, it appears very strange to me how an Indy with an MB background can’t find this issue with such a sophisticated piece of diagnostic kit at his disposal.
Anyway, a list of what you have done up to now would prove to be very useful so I can either rule them in/out if you wish to proceed.
Best Regards,
Dash1
Dear Dash1
What a wonderful answer, thank you so much.
The previous advice that I have cathered from various sources does suggest that it is an "authority to start" signal problem between the EIS and the GEAR SELECTOR but we are not sure which. This is because it has been intermittant and never seems to show up when the STAR is connected. Each would cost around £800 to replace, so before I gamble on one, I was checking out anything else that it might be and the STARTER SOLENOID could be guilty.
I have also replaced the BATTERY, CPS, and the BRAKE PEDAL SWITCH none of which was causing the failure to turn the starter motor.
I am happy using a multi-meter and would be very pleased to hear your advice.
Jumbojim
Dash1
I should add that I will do the tests you mention and get back to you soonest.
Thanks again
Dash1
I regret to say that I have been overtaken by events, the intermittant fault has become a permanant one. The car would not start at all and was stuck in PARK in Tesco's Car Park.
So I have had to have it taken away and dumped at my Local Mercedes Specialists. I am now waiting on him and his STAR machine.
Will let you know what happens.
Dash1
Hi Jumbojim,
Thanks for the update - I am really sorry to hear that. Apologies for only just coming back on to the forum, I work extremely long hours and don’t get the time to come on here daily. The only problem with intermittent faults are just that - intermittent. Never a very good sign when you come to diagnose the issues. However, you reveal a key piece of information now that wasn’t available in your opening post that I referred to in my post regarding the gear lever moving through its selector range - “P” through to “D”. I did ask you to listen for it actuating/clicking when you pressed the brake pedal with the ignition turned to the “on” position. I am not sure as to whether or not you actually got round to testing anything that I mentioned.
The starter lock-out switch, not the relay at the moment, which prevents the engine from cranking in anything other than “P” and “N” is another matter entirely, this lock-out switch is actually located in the transmission units valve block and takes on the form of an electrical type of “reed switch” and is wired in series with the ATF (automatic transmission fluid) temperature sensor. The ATF sensor - NTC (having negative temperature coefficient characteristics) will only work and inform the ETCM of fluid temperature parameters if the circuit is complete, in other words, closed contacts when the vehicle is running. If the lock-out switch is in a “closed circuit” condition when in “P” or in “N”, then the ETCM will not implement the crank process via the starter relay circuit, it needs to be in an “open circuit” condition so the ETCM actually monitors it as this to allow for cranking, as said, once running, the reed switch closes to allow for the monitoring of the temperature sensor.
The gear lever shift-lock, which again is another matter, is operated by an electronic solenoid in the gear lever housing/mechanism and is networked via the CAN bus. To operate this solenoid, an input trigger signal must be sent from the brake pedal switch to the ESP/BAS module and transmitted over the CAN bus to the ECM to initiate and activate the shift-lock solenoid.
Ignition key reset – The “P” and “N” starter lock-out solenoid (not to be confused with the shift lever lock- brake activation only) and the starter lock-out relay for the starter motor are controlled by the ETCM and ECM and it may require the ignition key to be reset by cycling the ignition switch “off” to “on” several times (slowly). Doing the above and recycling the ignition key can only eliminate error reaction.
Apologies for it being complex, I have tried to keep it as simple as is possible. Before we go any further in to any diagnostics, lets see what turns up from your mechanic with his STAR machine regarding any fault codes etc. The system is extremely complex and solely relies upon communication data from one module to the next over the CAN bus, however, some of the components are actually “hard wired” directly and are relatively easy to check/test if need be.
Out of interest, is there any excess “free play” in the gear lever linkage mechanism, the nylon bushings at the bottom pin do wear out and as a consequence make gear selection often difficult and gives rise to similar symptoms when it doesn’t quite go in to park or neutral. All the things that I have mentioned up to now can be checked and tested if necessary, but lets wait the outcome of your STAR test before I give you any additional test information.
Best Regards,
Dash1
Hi Jumbojim,
I forgot to mention this earlier in my last post that you could also get your mechanic whilst he has the vehicle to visually check the ETCM (electronic transmission control module) for ATF oil contamination. A condition that is known and referred to as “wicking” – capillary action occurs when the transmission adaptors 13 pin plug, prone to oil seal leakage results in the ATF oil gradually traveling up the wiring loom and in to the ETCM connectors plugs, which eventually contaminates the internals of the electronic module. Lots of electrical problems have resulted from this scenario.
Best Regards,
Dash1
Thanks again DASH 1 for those knowlegable posts.
The CL500 has been at the Merc. Specialists for 5 days now, yet his STAR is still unsure what the problem is. Best guess is the EIS itself so he is going to change that.
If that does not work, then I will present him with your ideas if you do not mind.
No alas, I did not get to do any of your checks as the car was lost to me before I could get to do them.
Gentlemen
Thank you for your help and concern about my reluctant to start CL500 over the past few weeks.
The problem was a breaking down EIS, and now that my local Mercedes Specialist has fitted a new one all is good once again.
The Ignition switch cost about £400, fitting about £100 plus VAT.
So I am glad to be back on the road again.
Jumbojim said:
Gentlemen
Thanks for the follow up Jim.
Hi Jumbojim,
Best Regards,
Dash1
Being a newbie, I don't have access rights to get in touch with Dash 1.
I am also in Staffordshire so I hope he gets to see this post.......Anyway.
I have a similar problem as described here a while ago.
I parked the car to do some MOT work in my drive. Recently got the car as a MOT failure and could not resist taking it away basically.
So after a few days working out stuff on the leaking offside rear shocker and knocking pump sound, I snipped the belt off. Found that the ABC pump is shot at (Lovely) and moved the vehicle quickly round into my larger drive.
Came to it the next day and the engine would not crank.
Key goes in, turn on ignition, all lights light....go to crank and nothing.
Gear shift is stuck in park.
Brake lights work.
No clicking sound from ESM area when ignition or brake pedal is pressed.
Removed green start relay out of Ofside fuse cluster, have 77 ohms on the coil and it clicks over with a pp3 9volt battery.
Turned ignition on and jumped the relay blades.......BINGO. Engine cranks in and fires up a treat.
Just will not crank off the key.
The green relay is not getting any coil input to throw the contacts over so there is some type of circuit let down stopping this from happening.
I have read here and elsewhere that there is this interlock from other areas.
Please could you expand. Hope Dash 1 sees this as I love informative stuff like this.
I cannot believe a module on the car can just go like that however, I had suspicions that the garage had jumped it using a few young ones.....maybe they fried something.
Cheers and thank you all any way for posting even if no one sees this
