Engineering Menu
alzieboy
over the Rainbow
E350CDI Coupe
Does anybody know if within the Enginnering menu there are any settings for the Nav SD card to enable the importing Data when sd card is slotted in the Ntg4.5 . for Nav PersonalPOI . This worked the first time i installed the sd card and the POI all worked well, I removed the sd card to install some music from another sd card to the music register, now the card with the POI on will not reinstall on comand !!! :wallbash:
Has anybody else put speed camera POI on their command unit via SD Card ?:(
