Hi Guys,
Had a nightmare today, cut along story short I was at work in London and got a call from the wife saying the car horn was blowing and she couldn't turn it off.
When I arrived home 2 hours later with the neighbours going crazy i put the key in the ignition and found the car showing ESP fault and steptronic fault.
I turned the engine over and then try to shut the car down but even with the key removed the engine kept running!
Bear in mind the car hadn't be driven a lot lately.
My most pressing question is what and where is the horn fuse situated, I have no fuse diagram to check and really need to make sure the horn don't just start going off while I'm away.
Once I get some time I'll drop it into the garage to get it checked over.
E280 2006
E280 2006
