D
Deleted member 151559
Guest
I will need a battery shortly......I wonder?
try Tayna - Car Batteries - Motorcycle Batteries - Leisure Batteries - Cheap Prices!
The sensor has to be about 3mm in diameter so if it has not triggered you must have way more than 3mm left ..or a faulty sensor ?Yes it has a single rear wear sensor, it has not triggered yet. I have had wear sensor wires break and fail to trigger hence checking brake wear rather than rely on the sensors.
The sensor has to be about 3mm in diameter so if it has not triggered you must have way more than 3mm left ..or a faulty sensor ?![]()
Hence my practice to measure and not estimate!This point , not based on any estimations, brakes are too important to 'estimate' on anything. On this set of new Akebono pads the sensor hole is 3mm and then beyond that is 1mm of pad material , so if the sensor works the moment it 'makes' the disc this pad would have 4mm of material when the dash warning lamp came on . Simple.
As you can see Akebono give you the ability to choose how much is left before you get an alarm by having the sensor hole closer to the disc in the opposite pad if you choose that option , track use etc.
I am sorry if you are offended by being asked a perfectly reasonable question regarding the amount of material left on your brake pads , I even said later in the post that I was just curious if you car had sensors or not .Hence my practice to measure and not estimate!
You still based your initial judgement and response on estimates plus we were not discussing Akebono pads so using them as an example is not relevant to the initial thread.
You do seem to have the need to prove a point even to the extent of bringing in other irrelevant "evidence" to try to support it. It is clear from looking over a number of your posts that you do not like being challenged and seem to have the need for the last word on a subject with, generally a classic passive aggressive response.
There are many genuinely interesting, intelligent people on here with whom it is possible to have a balanced and reasoned discussion and you do not fall into that category,.
Fortunately the ignore button works well.
SIMPLE![]()
Then you could complain about nothing being delivered!So the parts arrivedminus the engine oil lol. What a frustrating fricking delivery set up.
Either deliver all parts are fricking none. Dopes !!!!
I ordered 8 lts of oil on the 23rd March and have still not received my order and after sending several emails and trying to contact them by phone I have not received any reply. This matter has now been referred to Paypal for a full refund and I will never use them again.All or nothing for me!!!
Stupid strategy, complain to who don't answer phones or emails!!!
"Send this out" they won't need that engine oil to do a oil service. The filter and other bits will keep him busy![]()
I’m having similar issues with ECP... been waiting 20 days for refund!I ordered 8 lts of oil on the 23rd March and have still not received my order and after sending several emails and trying to contact them by phone I have not received any reply. This matter has now been referred to Paypal for a full refund and I will never use them again.
