trapperjohn
Welcome both of you aboard. The 230 engine is a stonker.
Any ideas for other things to check?
Very nice indeed, just thinned my fleet down, had :
Trex 150, Blade 130X, Warp 360, Goblin 700 & Raptor E700
but now only have the E700 & Blade 130X although I will have a 180cfx on Christmas day as well
No, MAF would be my guess if I had to have a bet. I've have seen first hand now on two C230K's faulty MAF's disengaging the the S/c clutch & opening the bypass air flap. Any fault codes?
If it does transpire to be the MAF, buy Bosch or Pierburg only and shop around too as prices can vary. You only need the MAF, so try and avoid buying the MAF housing too. Cheapest I've found came from Poland.
Funny you mention Poland - most of the parts i've purchased up to this point have been decidedly eastern bloc!
They'll repair anything & everything and usually do a good job too. Merc's are popular there, thus the good parts supply & low prices I'd presume.
P.s. Buy a fault code reader, a good investment if you haven't got one.
I'll look into a fault code reader, do you have any recommendations? I think Rachel would be less than impressed if she opened one on Christmas day!
Was the goblin as amazing as it seems on the web? I actually love my Sceaudu even though it's getting on a bit now - just a nice flyer. I'm certainly not a 3d stick banger, but i'm practicing loops now!
about £200 depending what level of diagnostics you want
It's the older 38 pin connector under the bonnet on the OP car so the Bluetooth and wifi dongles don't work
I use snap on diagnostics can be had on eBay for about £200 depending what level of diagnostics you want. I use a solus pro which is better at fault finding than star
danch said:Couldn't this be used ? : OBD to OBD2 Adapter along with a wireless reader ?
...can't get either of the ELM 37 wifi and Bluetooth dongles to work with it
Flango, out of interest have a look at it again because I understood it did work, on a C230K, also OBD1?
In fact, now that I think of it, I actually know someone using an ELM or similar via a Torque App and from what I recall it's working 100%.
If you can get any details it might save me a headache, the wifi ELM is fragile but the bluetooth version run on my Samsung tablet is bullet proof. First thing I do now when I go to look at a car is plug in the dongle and download the codes and history then I know if I need to look any further at the car
