Fault codes on gearbox w202 C43
amg3.6
UK
C55 Amg White W202
Any advice on these codes on what should be done and whats wrong.
My car went into limp mode and now it doesnt change gear.
Olly is there a fault code to tell you if car is in limp mode?
Its not in limp mode as such it just has a faulty component that will stop it changing gear.
The live data may show it to be in emergency mode.
So what shall i do?
Check the wiring back to the control unit from the electrical plug. Check the electrical plate for contuniuity. Then change the solenoid. If there is still a problem then look at the control unit. You have retro fitted a tip selector? Did you change the gearbox control unit too?
Yes retro fitted tip shifter. No need to change gearbox ecu olly
