Faulty dimming wing mirror glass
Riffman
2004 CLK 320 Coupe
Hi, Looking for any guidance on replacing a faulty dimming drivers wing mirror glass on 2004 CLK coupe. Yours Hopefully.....
There are a couple of alternatives for these.
Take a look at the link below and see if yours looks the same as the one I recently replaced on my C Class.
Must warn you that new replacements are £300+ from the dealers, but I picked up a used one in 'as new' condition off ebay.
The alternative is to replace it with a standard heated glass. Non dimming.
http://www.mbclub.co.uk/forums/2173168-post4.html
Edit: The one in the link posted by aircondon above is the same place I bought mine from.
Firstly double check it is the mirror at fault and not simply a broken wire inside the mirror casing.
Mine went brown.
I split the two glasses and cleaned the oily stuff out, then bonded back together around the edge.
I can live without auto dimming until a cheap one comes my way.
