OP
OP
Deleted member 113659
Guest
Thank you. Appreciate your input.I know this is not what you will want to hear but I wouldnt buy a second hand rim. For the following reasons:
1) Its a refurb rim, so why was it refurbed to begin with? Maybe be only surface damage or more you are taking a risk, you dont know the history.
2) This is the most important one for me, I personally had experience with rims (which were also refurbed by previous owner) which were over torqued i.e. tighten way to tight with an impact gun. This resulted in a nightmare situation with my new front brake disc warping after only 1000 miles. I ended up replacing two sets of disc before it was discovered the rim were actually causing the warping due to either over torqueing or the fact it refurbed. Had brand new Mercedes rims (x2) fitted no issues since.
Be careful when fitting your rims yourself, use a torque wrench (Halfords do one for £100) and torque to the measurements as defined in your owners manual. For me on the W222 sclass its 150Nm, also torque the bolts in the correct sequence they show in the manual to avoid any problems later.
WIS state to torque to half the recommended value first (75Nm) then to the recommended value (150Nm)
I hope this is of some help, if you buy second hand you have no idea of the history and could end up warping your brake disc and get that annoying shudder ever time you brake, a much worse position than you are in right now.
one here too. Never been fitted apparently.
GENUINE AMG MERCEDES C CLASS W205 19" 7.5J FRONT ALLOY WHEEL A2054015400 7x23 | eBay
Find many great new & used options and get the best deals for GENUINE AMG MERCEDES C CLASS W205 19" 7.5J FRONT ALLOY WHEEL A2054015400 7x23 at the best online prices at eBay! Free delivery for many products!
www.ebay.co.uk
