OP
OP
Deleted member 2227
Guest
your input is most helpful. Many thanks.
Am I alone in wanting 'wheels-inmotion' to check over my car ?
I mentioned that at the time and they assured me that it was the correct setting for my car....I did askScreens say "S203" -estate
Your car is a "W203" - saloon
Not sure if different settings are required![]()
Yes and no...... Longitudinal the castor cannot make the tyre wear but as the steering is turned the castor position aids the camber migration (inner wheel toward positive, outer toward negative) if the castor is wrong then the migration will allow the cars weight to become outside of the steer axis and wear the tyre.
I had a few attempts at getting my car set up properly.
Only when I found the correct method on the internet and had the car weighted did I drive away witha car I was happy with, it was a night and day difference.
Understeer no more W124!
Dave!
I am sure WIS states the car has to be weighted. I will check to see tomorrow. I maybe wrong??
Had mine done by STS in Hemel yesterday, full tank of fuel and kit in the boot, should have been £60 for the adjustment but they charged me £40 when I also bought some tyres for the rear. Had to return later as the printout they gave me was for a w204 even though as I watched they did select an s211 correctly. Just to be sure they rechecked the car and did find some errors from the morning. The printout and the display showed S211 E-T model, seems you need to select the t-model as the s211 is taken as being the w211 by default. this lead to very high king pin angles which could be costly to fix and not necessarily required
all four I think they did castor, the printout is at home and I am away so dont have access right now to check
