Copiertech
- May 21, 2005
You can gain a little top end power on the w168 A class by replacing the hose from the airbox to the grille snorkel with one with a larger diameter, you can feel an improvement from 3000 rpm upwards, the only side effect i`ve noticed is the sound of the engine has changed slightly at full throttle, it doesnt sound any louder, just a slight bit deeper. I like the sound, it might not be to your crannys taste though (not that your granny yould use full throttle much.
Also if the 2 brass pipes on the front of the throttle body are connected to the coolant circuit disconnect the pipes and bridge then with a bit of copper pipe, the throttle body heater is not needed in our climate and reduces power by making the inlet air less dense.
Another free mod you can do to any merc is remove the throttle spindle and very carefully cut out part of the spindle. you have to be quite careful doing this one to avoid binding and thinner spindles can snap so only do it if you are confident at engineering and dont blame me if it goes wrong
![170920057sq.jpg](http://img26.imageshack.us/img26/5592/170920057sq.jpg)
![tbspindle9qn.jpg](http://img29.imageshack.us/img29/5848/tbspindle9qn.jpg)
