2007 C220cdi estate, W/S203. Both my front tyres are very badly worn on the outside - down to about 1mm with the inside still about 5mm. The passengers side is slightly worse than the drivers. Is this normal ? If not, I don't want to replace them only for it to happen again. The car has done 18200 miles, and has always pulled hard to the left - been told it's very camber sensitive. Alignment was checked and adjusted by Mercedes a couple of times for the pulling but I gave up in the end.Adam
