Sorry to resurrect such an old thread
I have a CLK 270 which wears the outside front tyre edges, the nearside slightly more than the offside.
The last inch of offside tread is completely gone while the rest of the tyre has around 4-5mm on it. (The tread depth increases rapidly away from the tyre edge).
The suspension alignment has been checked independently by three different local garages (although not by MB or a specialist of WIM's standing)
The alignment is within spec, in fact the toe in is at the lesser end of the spec (i.e. any less would be erring towards toe out) and the front tyres have done 12-15K miles.(Contisports)
One of the local garages has suggested that I should allow them to adjust to give less toe in to reduce the problem, if this is a reasonable approach then how much adjustment should be necessary to achieve less aggressive tyre wear?
For the last 3K miles I've been running with slightly higher tyre pressures on the front (around 34psi) and slightly lower on the back (around 30psi) as my rears also have the well known problem of higher wear in the centre. The rears aren't so bad at about 1mm difference, they were on their way out anyway after around 25K
Increasing the front pressures seems to have slightly reduced the edge wear as suggested earlier in this thread but having bought a full set of new wheels/tyres I want to make some pro-active attempt to improve the front wear characteristics.
Interestingly the garage have another customer with a CLK 270 of similar age which doesn't appear to have the same problem
Does anyone have any suggestions how much less toe in adjustment would help?
