Gear selector tiptronic problem
Vejay
Cornwall
Clk 320 cab Carlsson
Sometimes when I start car as you go to reverse it jerks back the move on to drive and back jerk forward if you drive first only if you try to shift to park stops at neutral unless you turn off ignition. Go through this stop start a few times and it's ok again for a day or two or maybe an hour!!!
Spilt a bowl of water in the back behind passengers seat now floor in front footwell is very wet is there something there that doesn't like the damp, have been told that gear selector unit is at fault
