gearbox odd feeling? UPDATE
Hello,
Don't know how to call this then here is the best I can explain. This as been going on for awhile. Not more nor less. Same.
Sometimes when I push the pedal at the near stop but going up on speed again, there is a feeling like like the car just got in gear, like a little clunk, and sometimes when I brake, when I am on the near stop the car got a wee momentum like if if there was a wheel still spinning and engaging at the near stop giving the car a little humf forward. Will that be the first gear playing? Asking about the first gear as I don't know for how long the car was on second ( Years?) as the little plunger in the gear shift was glued and therefore always on W, only found out 3 month after having the car.
Thank you.
Olivier
Hello,
Thank you.
Olivier
