Hi All,
I have a '98 E280 Elegance and it's developed serious gearbox problems. I had EXACTLY the same problem back in February with all the symptons EXACTLY the same. The problem was solved by changing the gearbox oil/filter/sump gasket. Now, a lot less than 10,000 miles later...
At the beginning of last week I lost all drive to the wheels and was left crawling across a roundabout with the engine revving uselessly. The first sympton to happen was a loud, high pitched whirring noise that raised or lowered in pitch in relation to the engine revs. Next it became a bit sluggish to engage gears and then rather than changing gear smoothly, the revs would flare between gears. Finally I was left being unable to select gears.
I have finally got round to having a look at what was going on today (working and the Silverstone Classic were priorities...). I have measured the level using the correct measuring tool from MB and adjusted the level of oil (it was slightly over the max mark and was fine in colour) so that the oil reads about 1/2 way between the minimum and maximum marks on the tool for the 2 markings for when the car is fully warmed up. I also took the measurement while the engine was running. When we first started it up the whirring noise was still there but disappeared after a short while, making me think that it just took a little time to work the oil round. The car was engaging the gears (could feel the slight twitch in the car and the lowering of revs) ok.
I left the car for 10-15minutes and returned to it later to give it a run on the road. When I started it up the whirring was there again. While I retrieved the measuring tool the noise went away! The levels were ok as before. I then tried to move the car and it would engage the gears but there was no drive to the wheels! I switched off the car and left it for 30 seconds or so then started it again. The noise had returned but it allowed me to pull it back onto the drive.
Sorry for such a long post but I've tried to put in as much detail about the problem as I can. Any help would be gratefully received
Thanks in anticipation,
SteveyT
SteveyT
