I've recently acquired a 2003 E320 petrol car
I'm not very happy with the gearbox performance. On start up there is often resistance to moving (as if the hand brake is partially engaged) Once I've overcome this it starts to move slowly in what appears to be 2nd gear. If I press down on the accelerator, even gently, it will kick down into 1st suddenly and with vicious acceleration I have to let off. This gives it a very jerky ride. After I've gone a short distance (100 mtrs or so) it gets better but then it will often hold in 3rd at 30-40 mph and revs at 3000 + rpm. I'm sure this can't be right. The fuel consumption accordingly is terrible 14 mpg'ish
I've checked the transmission oil level and it appears to be exceptionally high. It is well above the black plastic indicator and well onto the metal coils.
Could this be causing the erratic fault ?
Can anybody help ?
Can anybody help ?
