andydtaylor
- Nov 22, 2010
Hi all,
Driving to work today I experienced a loss of power. Like the car had gone into Limp mode*. This also happened a few weeks ago as I was overtaking a lorry (up a hill). On that occasion, I limped to work, turned the engine off/on and the problem was gone.
* the effect is a lag after you put yout foot on the throttle, and then the power is released much more slowly than usual.
Today, in similar circumstances (overtaking) the same issue arose twice.
1st time - I turned engine off at roundabout and restarted it, problem gone
2nd time the engine/transmission light came on and after limiping to work tried turning it off/on but the light and problem remained.
I managed to get booked in to the non-Merc garage round the corner from work at lunch time and limped it in for a diagniostic.
These were the resulting codes:
P20DD - B37 (Accelerator Pedal Sensor)
P2600 - Circuit 87 Voltage Too Low
P2314 - CAN Communication N23 9Electronic Ignition)
P2316 - CAN Communication A1 (Instrument Cluster) Faulty
Conclusion was 'Accelerator throttle sensor' needs replacing - but the mechanic says he was unsure if this really was the case based on my description, and the fact that the parts person his assistant spoke to reckoned there wasn't a replacement part. We agreed I'd post online and see what the feedback was.
He cleared out the error codes and we went for a drive to see if they'd come up again but nothing did-it drove without fault.
Is the problem as abovious as a throttle sensor? Any thoughts as to what this might cost to fix?
Thanks,
Andy
Thanks,
Andy
