Given that the manufacturer's suggested tyre pressures are just that - a suggested range given a number of different factors - they're the starting point for working out the right pressure for your car.
QUOTE]
Correct!
There is no one right answer and it would be great if there was system like Airmatic for tyres which would vary the pressure for different situations.
If you have more load you need more pressure. If the tyres get warm you need less. For ecomomy you need more. For outright grip you often need less. For ride comfort less is more. Longevity will mean triming the tyre pressures to suit the conditions.
So what is important to you today?
Mercedes car generally run higher pressures for larger diameter wheels. My S class recomends + 3 psi when you move from 18 or 19" wheels to 20"
So I've gone and put 21" on!
