- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
You lucky couple! Siena is a very special city (I prefer it to Firenze, actually) and with 5 days to drive back you should be able to have a really enjoyable time. Don't forget to visit San Gimignano and Volterra while you're in the area if you get a chance. In addition to the excellent advice already given, I'll add:
- Buy yourself the orange Michelin maps covering the areas you want to head through
- Pick roads with a green edge on the Michelin maps (these are scenic roads) and the best are stunning
- In general, mountain miles take a long time to cover: you can spend all day and clock no more than 150-200 miles if you pick the "right" roads
- Plan to get to your destination mid-afternoon each day, that way you get a chance to relax and take a look around. It'll also give you plenty of "extra" time should you find something of particular interest en-route that you would otherwise have to skip past
- The long tunnels (like Mont-Blanc) are a bit of a novelty at first but are dull, boring, quite expensive and can also be full of trucks. The road route over the Cols is much more spectacular and rewarding to drive but will take a good deal longer. If you factor in the extra time then that won't be a problem though
- Annecy would make a pleasant stop off and Calais is easily do-able from there in 2 gentle(ish) days on D- and N-Roads so you could spend 3 days getting from Siena to there
- The motorway route around the coast from north of Pisa to Genova (and beyond!) is pretty spectacular and would allow you to crack off a few easy miles on the first day before heading north-west past Torino
- Then 2 days messing about in the mountains
- Then Annecy and home...
- With care you can traverse Switzerland without using their motorways and hence won't need a vignette, but this can be quite difficult to do as the Swiss set their roadsigns to direct you towards the motorways seemingly at every opportunity
- As well as radar detectors being illegal in the countries you'll be visiting, even GPS-based speedcam warning systems are illegal in Switzerland
