Charles Morgan
- Feb 2, 2010
- Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
Right, some help needed, as to paraphrase Winnie the Pooh, I am a bear of very little brain and electrical circuits bother me.
My old headlight reflectors for my W114 house side and headlights. Despite not being for H4 bulbs there were H4 bulbs in each. There are two connections on the fixing. One for sidelights connected by a single grey wire and one for the headlights connected by brown wire to a socket that is also attached to the sidelight bulb. The brown wire goes on to the indicator lights and comes from the same connection that sends a like brown wire to the fog lights. Picture A & B shows the main beam terminal on both sides - it is difficult to make out but the grey connector for the sidelight is mounted into material that is not conductive.
I am confused as to how with only two connectors a separate headlight and sidelight circuit could be maintained but let that pass pro tem.
I bought two unused reflectors made in Turkey under license. This is clearly designed for H4 bulbs. As can be seen from Picture C there is only one terminal on the central mount. I assume therefore the bulb connectors that fit the new mount are set up differently to the old ones.
I have new H4 connectors with three leads (I am assuming Positive, Negative and Earth) one black, one white and one blue. Could someone kind give me a means of pulling together with the existing wires and or the new H4 connector (and indeed any other bit of wire I may be missing) so that I can connect up the headlights and the sidelights and they will all work when connected to the loom of the car (assuming that works). I have been puzzling over this for hours.
If for MOT reasons I don't need sidelights I can happily live without as dipped beam is far more sensible.
