Mercedes 230te
- Sep 27, 2014
- Mercedes 230te
Ok. Thanks grober
Yes this is the M102 SOHC engine. ThanksI am assuming this is the M102 engine, which is SOHC, in which case the misfire could also be result of cam timing or other camshaft-related issue. A compression test will help diagnose the issue.
If it was leads or cap wouldn't it misfire all the time?
Wow. Thanks very much.Not necessarily. Varying degrees of moisture (cap) and or vibration (leads), and the conditions within the combustion chamber (which vary across the operating range) are all factors.
I'm going over today to check the cap
and I'll check the leads for tracking when it's dark.
Also I want to check the spark on the plugs, do I do it one at a time or all at once
Do you have any thoughts on the jumping in to reverse?
Nope! Auto (presuambly), if not the external linkage in need of adjustment then some internal problem I'd imagine.
I'm not sure if the level is correct as I can't test it until it's been on a run for a bit. I can't take it out at the moment as it's not insured. The level at the moment is way above max but I have to test it once the gearbox has run up to temp. I'm not sure what a B3 clutch is so I couldn't tell you.Assuming correct level and fluid, jerking transmission could be flex-disks or engine/transmission mounts, but if it only does it going into reverse sounds like a gearbox fault?
B3 Clutch on reverse gear ?
