heater blower fan (stoped working) repair is easy
window cleaner
:bannana: ive found the solution to why my heater blower fan stoped working , it was the bushes,the way i fixed it was to take the bushes out of a old vacume cleaner,they may be a bit bigger but u can easly file them down to fit,leave as much wire on them as possible,remove the old bushes from your fan again leave as much wire on as u can,twist the two end together and put a bit of solder on them,and refit,do the same to the other side then put it back in the car,and hay presto my fan working again,cost nothing just a old vac and a bit of time .
Excellent result, well done. Total cost zero.:)
