HELP! air compressor needed for w124 E250d
exportstrength
ce220
Hi , just on the finishing stages converting my W124 CE220 to Diesel (250D 5 Cyl) in the UK and realised i needed the old air compressor (which i disposed of) in order to fit the belt properly, , i have gone for no air con , but it needs an idle bearing and pulley arrangement or just an old air con pump , IF ANYONE HAS AN OLD PUMP I CAN PURCHASE THAT WOULD BE THE EASIEST OPTION for a W124 2.5 diesel . Thanks
Belts are available in different lengths. Usually measured in mm length. I took the aircon off my 606 engine and got a belt from Merc to suit no problem.
Yep thats what i thought , got the shorter belt (a little shorter) , but that belt is for an idler pulley as it needs to be directed downwards to avoid the vacuum pump then up to the power steering pump , but it's all good , i have an old AC pump coming to sort it , Thanks for the help
