HELP! Injector Pump C250
Scania-Man
Merc C250 Turbo Diesel
Hi guys I posted this off to a guy who supplies electric fuel pumps:
Ive spotted your added on ebay and wanted to ask you a question before ordering a fuel pump. I have a C250 Turbo Diesel Merc 1997. When I got the car home after purchasing it I noticed a knocking noise. Upon inspection I notice that an electric fuel pump has been added to bypass the original one on the car, no doubt to save the replacement cost. If I purchase another electrical one from yourselves will it be sufficient for the car and will it make the annoying knocking noise it currently does?
I'm short on dough at the mo and was wondering if any of you had done this or know of anybody that has done this as a temp measure or in order to save money? I think injector pumps are around the £300 mark from a breakers and the bypass electrical one around £30-£40. I am happy to fit an electrical one again but this one makes an annoying knocking noise.
Any info would be most appreciated.
have you checked the injectors? and also for excessive air in the system?
Thanks for your reply Silversaloon.
No, it is just a temp thing to fit another (less noisy ) electric pump. The car seems to run ok but I was wondering if I would cause more damage or totally wreck the engine!
So just a temp fix until money isnt as tight.
thanks
is it the lift pump that is getting bypassed with the electric pump, or have i misunderstood?
whats wrong with the original lift pump? pretty robust, or pennies to fix.
Think I have been barking up the wrong tree, sorry. I have been told that the C250 td has a fuel pump in the tank, so now I'm assuming it is this that has failed and this electric pump under the bonnet it doing its job.
I'm getting a mechanic to look at it this week but and you recommend where to buy a replacement one from or can they be repaired ? Any help most appreciated.
