I just use a long 8mm ring spanner with a 12" bit of 1/2" pipe welded on one end.,
I lever the tensioner to allow the belt to slip off and carefully let the spanner go back to rest.
Remove old belt.
Slip on new belt (if you can remember the route!
Pull tensioner back and slide belt over tensioner "Mind fingers"
