Help needed with Defective Display msg (W210)
westy2005
Barnsley, South Yorkshire
Mercedes E300DT
Hi all,
had the above msg on the car since i bought it, so decided to replace the washer bottle sensor and the coolant level sensor to eliminate the issue as im aware that they work in series - but ive still got the same problem showing on the dash - any ideas as to where/what to try next.
i replaced them one after the other and each time the error msg was shown.:dk:
To add, on the old washer sensor after stripping down i could see that the wiring and resistor had perished.
thanks in advance
sam
issues solved - no warning signs at last.
unpluged all of the new sensors and refitted but same issue, as a stab in the dark replaced the new coolant sensor with the old and it eliminated the problem.
Nice to know you have sorted it
Martin
