Terry_
Auhorised Forum Sponsor
The 55k engine is straight forward
This SL really caught my eye. OK its a 2004 model, but it looks well cared for.
Used 2004 MERCEDES-BENZ SL CLASS SL 55 AMG 2dr Auto SUPERB SPEC & COLOUR for sale in Middlesex | Pistonheads
Thanks for that.
I spotted it a few days ago, and had a good laugh at the dealer's description that includes:
"...LOVED BY ONLY 5 FORMER KEEPERS FROM NEW..."
Only 5?
If one assumes that an outgoing owner might be a bit slack about maintenance just before its time to sell, then that's 5 owners who may have skimped a bit.![]()
55 every time but I'm biased...
No car empties your bank account as quickly as a bi turbo V12.
Yes the 600 is faster in a straight line than the 55k, but only by a whisker. The 55k has built up a reputation of solid reliability and reasonable maintenance costs when they do have the minor hiccup.
The 600 can easily empty you of thousands of pounds for a misfire due to coil packs etc. That's just the tip of the ice berg. Due to heat soak, coil pack failure is very common.
Contrary to popular belief, V12TT are actually okay to own and run daily. A bit more involving to maintain (cooling circuit needs a machine to bleed) but not much to go wrong with them and M275 has only recently been "discontinued". In fact, the design was so successful, the new M279 is only a slightly modified version of the M275.
Coil packs lifespan or heat soak won't be any different to a V8K but (to Pitts Pilot) they cost more as there's 2 pairs of six of them in a V12 and you can't buy less, hence the higher outlay. That said, they don't need changing as often and could easily last 80k+ (my CL600 had an original set when I sold it and it had 87K on the clock). Besides, they can also be repaired.
You're mistaken I'm afraid, you must be the lucky 1. We've known 600s with coil problems at under 40,000. Please point me to someone that repairs them. BBA reman used to apparently. As far as I can find, there is one place in the states that does them now but they are very expensive.
The central voltage transformer regularly needs replacing if the car is driven with coils breaking down.
Coils are somewhere north of £1000 each and the voltage transformer isn't far off of that.
Our own V12 bi-turbo is currently in the garage with this problem. It's now a toss up as to whether the car is broken for spares or repaired. The car is fully loaded with every option and designio interior but it's still worth only so much.
