marty62
Hi Everyone. My 1994 E220 Coupe developed a misfire which was cured by changing the ECU. The wiring to the coilpacks is in good condition, so I assumed the fault was with the coil packs themselves and changed them. I'd like to try to repair the original ECU. The MB part number is 016 545 55 32, and its Bosch part number is 0 261 203 230. It is an HFM system. I'm assuming that one or both coil drivers is damaged - an easy repair if I can identify an appropriate replacement.
I've attached a photo of the circuit board of the ECU. The coil driver transistors are the two black devices standing vertically at the far edge of the board (with clips and heatsink removed for clarity). They are 5-terminal devices (which rules out the BU931 discussed in other threads on this forum). Three alternate leads are formed forwards, with the other two formed backwards. There are no manufacturer logos. The characters 008466431C can be found on the lower front face of the devices.
The pin-out of a BU931 would be compatible with the front 3 pins of the original device. However I also need to consider the rear 2 pins because they are connected and must perform some function. (Perhaps they monitor temperature or current fault conditions)?
Does anybody have any information about the 5-pin devices please (e.g. manufacturer, part number, data sheet, how to obtain)?
Thanks in advance, Martin
