high beam relay location
blunders
a170
Hi, can anyone tell me where the high beam relay is on my 1999 A170?
thanks
thanks for the info, apparently there are some relays in the engine compartment, i cant find them, any advice pls?
I would be surprised if the main beam has a relay at all, normally the power is fed through the lighting switch and then the column stalk and to the lights.
