chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
Sounded horn yesterday & it stopped mid toot. Checked & cleaned connectors to horn today without success. I then discovered the horn fuse had blown(53A) which I then replaced but blew again immediately although I got a muted toot out of the horn. Did I understand correctly that if I disconnect the horn(presumably I have to connect the connectors with a paperclip or simiar to complete the circuit?), sound it & the fuse does not blow then it's the horn & if it does then it's the circuit? If it's the circuit where do I start to look? How do I remove the steering centre boss? I'm not sure if I am imaging it but the centre of the boss under the Merc badge does feel a bit soft. Any suggestions gratefully received.
