John Jones Jr
- Mar 23, 2013
- Location
- London & Dublin
- Mazda MX5 10AE, W201 2.5-16, W202 230K Sport man, Honda Accord & Suzuki 'Ricer'.
Hoping somebody can assist, '98 W202.
I've two problems, I think? Originally, my first problem was the n/s main beam would not work at all and the o/s would not flash and no main beam dash warning light. So, I found a fuse gone, No.34. (7.5amp) which is for the n/s main beam & dash warning lamp. Fuse replaced and both main beams working and flashing also dash warning light working too but... the horn operates now while using main beam! The horn will not work otherwise.
Also, at the same time combi the switch failed to work, on indicators & windscreen wash/wipe. Actually it blew fuse No.22 (10amp) as I tried to operate the wash/wipe.
Now, why I'm unsure if I've got one or two problems, simply because the windscreen wipers, w/wipe, indicators & headlamp flasher all share fuse No.22.
Just add, I replaced No.22 fuse and wipers, indicators & main beam (with horn) all work. Fuse only blows when w/wash is operated.
Any ideas or advise greatly received.
