LGGVW
I think 400mm to a max. 500mm. It means I can sit on a low stool and be relatively eye-level with the wheel arches.How high do you want to get the car ?
Depends if it is a male or female measuring....How high is an axle stand though ?
You're not the first to think that. They open and close fairly regularly, as people fail to make the numbers add up. Property, facilities, insurance, staff, business rates. It's all like your local MoT station without that regular stream of steady income.I did. I am aware there are garages which offer lifting bays for hire and mechanics on-hand for a bit of help if necessary, tools, etc.
I live in County Durham, could not find one. Maybe there are available, just not advertised or I am not searching in the right places?
BTW, this is such a great business model idea for anyone with enough capital available to invest! I would if I had the capital for it!
Any wealthy investors out there?
It's been done quite a lot . Less popular now , my guess is it might have fallen victim to the nuances of 'elf & safety/public liability insurance etc.I did. I am aware there are garages which offer lifting bays for hire and mechanics on-hand for a bit of help if necessary, tools, etc.
If you are actually serious in that response I urge you to rethink. That is a ridiculous height to be raising a car to especially raising one end at a time. Raise only as high as required for access. Your comfort is not a priority.I think 400mm to a max. 500mm. It means I can sit on a low stool and be relatively eye-level with the wheel arches.
I had issues with SGS jacks, cheap and you get what you pay for.That SGS Jack looks sturdy, but at 465mm fully erect, it might not be long enough.
I once bought a SGS compressor - utter crap. Sent it straight back and spent loads more on a decent belt driven model from a proper compressor manufacturer.I had issues with SGS jacks, cheap and you get what you pay for.
And then the customer service is worse.
I favour the Sealy. Superior in every way, and only a few quids more.
I get your point completely. I am serious insofar as lack of experience goes. I never lifted a car before, so this thread is exactly aimed at getting feedback from the more experienced in the community here.There are very few tasks that require both ends of the car to be raised simultaneously (except for removal of all wheels for say, refurb - in which case tyre just clear of the ground is sufficient). What work are you proposing that requires all four corners lifted simultaneously?
Think of it this way - the higher the car is raised, if it topples, it moves the same distance sideways (towards you) as it was raised - and with greater momentum. Your chances of jumping clear are minimal and the consequences horrific.I get your point completely. I am serious insofar as lack of experience goes. I never lifted a car before, so this thread is exactly aimed at getting feedback from the more experienced in the community here.
You really don't need so much height for that. And, you should split it into two jobs - front and rear.The work I am considering is to remove the wheels, remove the wheel arch liners, clean, steam blast the inside of the arches, check for rust, convert the rust, and then treat the arches with DINITROL, or ACF50. Then steam blast the liners, spray both inner and exposed sides with ACF50, remount them, and remount the wheels.
Hi,Think of it this way - the higher the car is raised, if it topples, it moves the same distance sideways (towards you) as it was raised - and with greater momentum. Your chances of jumping clear are minimal and the consequences horrific.
I've lifted a car at both ends simultaneously (reluctantly) and it isn't easy or for the faint of heart. Then there's lowering it when done and that's every bit as hazardous as lifting.
I can see why you want to do it in a 'oner' but split the job, raise each end as far as you feel comfortable with, reduce the risk and anxiety and the task will be a lot more relaxing.
If it was a good business model then it would have attracted the investment.I did. I am aware there are garages which offer lifting bays for hire and mechanics on-hand for a bit of help if necessary, tools, etc.
The stability at that height is very low. It would take little force to destabilise the car and have it fall.They vary, I have seen a few going as high as 650mm
What I've said will make more sense once you get started. Lifting both ends requires lifting each end in stages to keep it 'square'. Lifting the whole height at one end without the other creates a force equivalent to around one fifth of the car's weight - trying to topple it off its restraints. Bear that in mind when working on the rear. The front wheels have to be very very securely chocked.Hi,
Thank you so much for the advice. I have taken notice and will do what you just advised.
You're right. I did think about the potential risk of lifting the whole car in one go. The risk is too high, I get that.
I seem to remember that there are already rubber/plastic inserts already in my jacking points, are these necessary also?You buy rubber pads that fit the sill slots for the top of the axle stands (eBay )
This is the sort of thing , but the axle stand ones have a slot in the bottom as well![]()
Jack Pads Rubber Pad Adapter Fit For Mercedes Benz A B C E M R S CLA CLK Class | eBay
(Item included: 1 x Jack Pad. 3) Easy to use. Material: Rubber. 2) Perfect match for the original one.www.ebay.co.uk
Mine on both MB’s are just plastic slots to receive the thingy’s in the picture . Are yours different ?I seem to remember that there are already rubber/plastic inserts already in my jacking points, are these necessary also?
Yep I use them or at least similar one‘s , I‘m not sure that all the BMW ones fit MB’sSomething like this for axle stands?
