television
Hardcore MB Enthusiast
Though MB state the you cannot work on the SBC brake sytem without STAR diagnosis, there are two ways that this can be done.
The SBC pump has a large multi plug that can be withdrawn, then pumping the brake pedal till it sinks to the floor (10 pumps) it has been done this way with no problems encountered.
My chosen way was park the car with the wheels straight ahead, and then disconnect both batteries (if two) pump the pedal 10 times or until no presure felt. Do check the level of the top up tank, if very high remove some fluid.
The fronts on all SBC fitted cars are standad callipers with the 2 pins to knock out, the pistons can be withdrawn as standard practice on normal brakes. I could do mine without the need to turn the wheels away from the straight ahead possition with ease.
The rear are the standard 7 mm screws where the calliper lifts off.
Cars fitted with SBC have no known battery connection problems, the car where the owner unplugged the pump was a E class and he even started the car to change the lock, though he had no problems, I would not choose to do that.
On my 230 , it was only necessary to sinc the two windows and the ESP.
I used EBC green pads as i hate dirty wheels.
Malcolm
Malcolm
